I'm playing with a simple DI circuit in the simulator and here's a very strange thing that's happening. I'm following the output of the DI with a basic non-inverting op-amp block. When I use JFET op-amps, everything is fine. But when I put BJT op-amp, the input and output pins show a huge DC offset. I tried another DI topology with FET input, and the simulation behaves the same. Strangely enough, when connecting the generator to the op-amp directly, everything is fine and works as it should.
Any ideas?
EDIT. Damn! Found the culprit - forgot to put a resistor to GND for proper AC coupling. Doh!
Strange simulation results
Re: Strange simulation results
The JFET shouldn't have worked either.... I grew up before sims....
Yeah, you gotta wonder why the JFET version sim'd OK.
Back in the early days, sims were only as good as the models engineers loaded into the software and it was kind of like you had to know the answers to ask it the right questions.mediatechnology wrote: ↑Fri Oct 13, 2017 8:18 pmYeah, you gotta wonder why the JFET version sim'd OK.
I rolled my own DIY filter design sim, but never found circuit design sims very trustworthy, I'd much rather melt some solder.
Me too. Where the rubber hits the road.I'd much rather melt some solder.
My spreadsheet calculators for resistor values, CMRR etc. are kinda handy but I'm not sure I believe them until I confirm it with a scientific calculator and then finally melt the solder.
My filter software saved me many hours dialing in multipole filters (including embedded pre/de-emphasis networks). With the program (written in basic on my old H-11) I could plug in real cap values and see how close i could get to a target response... before melting solder.
OTOH I had a bad habit of using some semiconductors in unconventional ways with body diodes and intrinsic substrate diodes affecting real outcomes.
IIRC one of the things Rosalfonso and I had to accommodate when he simulated the Phantom Menace II is how power supplies were modeled.
The simulator treats them like stiff batteries or 0Ω sources able to sink and source current.
In the real world, with real voltage regulators, the results were entirely different.
I'm planning to use this DI circuit in the first post in the transformer input class-a mic preamp. Where is it better to put this circuit - before the transformer or after? Aside from color and "free" gain before the transformer is there any other pros/cons?
Pardon me for resurrecting this topic with a question not relevant to simulation. Creating a separate topic seemed to me an overkill.
Wouldn't you want to put it in front of the transformer (or along side it) in order to preserve the high impedance input?
Otherwise the transformer is going to load the instrument you're trying to DI.
In "after the transformer " case it will be either transformer or DI. DI is a physically different input jack. Switching is planned with relay.mediatechnology wrote: ↑Sun Feb 11, 2018 4:46 am Wouldn't you want to put it in front of the transformer (or along side it) in order to preserve the high impedance input?
