So, looks like the TDK/Lambda CC6-2412DF-E DC/DC converter can be wired with floating input, and is fine with either side of the output grounded, to achieve SE PSU voltage, either plus or minus. Looks useful, if I'm interpreting correctly. Not an idea I've delved into before. The addition of turn-on circuit looks essential. I'm thinking, possibly foolishly, about some -30VDC transformer coupled stuff in a 500 series rack. May play with it, and blow some stuff up. Any DC/DC PSU wizards have anything to add?
I spotted this over at PP, and this was Dan Kennedy's pick for the Great River MP-500NV preamp, which is +24VDC I believe.
Data sheet:
http://us.tdk-lambda.com/lp/ftp/specs/C ... spc_en.pdf
+24Vdc from +/-15Vdc
Re: +24Vdc from +/-15Vdc
Doug:
The second and third from-the-last connection examples here http://us.tdk-lambda.com/lp/ftp/specs/C ... df#page=15 seem to indicate that the input and outputs are floating and that you can common them or use it to provide negative output.
Wayne
Wayne
I'll report back, smoke or no.....
