Re: Using the THAT1646 As A Transistor Pre-Driver/Headphone
Wow, thanks for the feedback Greg!
You sure can use a 1243 but I would recommend a 1240 for most headphone builds.
I built most if not all of the line amp versions with 1246s but I never found a headphone application that required the added 6 dB attenuation of the 1246.
Still, with some phones (e.g. 300Ω 102dB/mW) you may not have enough gain even with a 1240.
I do offer a new version with gain and "0Ω" output you might want to consider: http://www.ka-electronics.com/kaelectro ... lass-A.htm
On this board you can eliminate the balanced input completely if needed.
