Passive Mastering EQ
New and vintage Pro Audio designs featuring things that glow.
ruffrecords
Re: Passive Mastering EQ
Post by ruffrecords »
Gold wrote: Wed Sep 10, 2025 1:15 pm Thanks Ian. Very helpful. I plan on using a beefy input buffer so the characteristic impedance is not too concerning to me.
The beefy input buffer will make no difference to the characteristic impedance of the EQ. This is determined by the resistor ladder and assumes the input is driven by a low source impedance (i.e. beefy).
The characteristic resistance of this EQ turns out to be very close to 400 ohms. You should use this and your desired Q and frquency to calculate the inductance.
Cheers
Ian
Post by Gold »
ruffrecords wrote: Wed Sep 10, 2025 2:47 pm The beefy input buffer will make no difference to the characteristic impedance of the EQ. This is determined by the resistor ladder and assumes the input is driven by a low source impedance (i.e. beefy).
I meant I planned on using a JE990 to drive the EQ network. It can drive 75Ω to +24dBm so it's no problem.
ruffrecords
OK.Let me know how you get on.
Cheers
Ian
Gold wrote: Wed Sep 10, 2025 3:20 pm
Paul - If you don't already have the JE-990 you might look at the DCAO. Bob Katz is using a fully balanced pair to drive a Gyraf G21 which is a very difficult load.
Post by Gold »
mediatechnology wrote: Fri Sep 12, 2025 7:31 am
I have 25 990’s. I bought them for something that didn’t happen. I’ll use JLM Dingo boards. I already use them for line amps with gain. The Dingo will work well for this and I have them.
Post by Gold »
I've been thinking about this some more and I think I have a rough plan. To realize my "stacked shelving EQ" the overall gain would need to be increased. My original idea was to have a 10 band graphic looking EQ. Five low bands and five high bands. +/-3db with all bands adding. That would need 15db overall gain to work.
After thinking about it some more I think I will try a 4 band shelving EQ. Two low bands and two high bands. The 'upper lower' band having something like 850Hz, 650Hz and 450Hz. Boost only 6dB. The 'lower lower' band being something like 250Hz, 150Hz and 50Hz Cut only 6dB. Same kind of thing for the high shelves. This should give me what I'm after.
AnalogJoe
Post by AnalogJoe »
ruffrecords wrote: Tue Sep 09, 2025 3:46 pm
Gold wrote: Mon Sep 08, 2025 4:37 pm
ruffrecords wrote: Mon Sep 08, 2025 3:46 pm There is no official agreed upon definition of a centre frequency for a shelving EQ. There are essentially two turnover frequencies; one where the the boost/cut begins and one where it ends. Personally I now use low Q bell curves instead of shelves because they allow the control of the out of audio band response whereas shelves do not.
I look at a shelf like a 'half bell'. For a low shelf the center frequency would be where the boost begins. At what would be the center frequency of a bell. the upper frequency. The lower frequency, the equivalent to the skirt of the bell would be where the boost ends.
How these are labeled is up for debate. For low shelves it makes sense to me to label the EQ point according to the 'center frequency' of the shelf. For high shelves it makes more sense to me to label according to where the 'skirt of the bell' starts. But for technical purposes I'd label it the same as a low shelf. where the 'center frequency' defines the label. It's done this way on a Sontec. They call the high shelf 10K when that's where the boost flattens out or is the 'center frequency'. But from a sound standpoint I'd call it a 1K high shelf because that's about where the bell skirt is. Where the skirt is depends on the Q of the shelf.
What's the formula for figuring this out?
Unfortunately, the formula you require depends critically on what you define as "where the boost begins". Is this 0.001dB of boost or 0.1dB of boost or 0.5dB of boost? A similar problem exists if you try to define things in terms of where the boost ends. I think you will find it far more beneficial to look at the actual curves obtained using a simulation. This will give you a much greater insight into haw the EQ works.
"Standard" RC or LC network formulae for this EQ are equally flawed because they give the theoretical frequency of 3dB boos or cut. Unfortunately, for an EQ with a maximum boost of 6dB, the 3dB point is very inaccurate when given by the standard formulae simply because it does not account for the 6dB boost limit.
As I mentioned in an earlier post, the intention is to make both arms of the resistive ladder equal to 600 ohms. With that in mind I have attached a simple LTspice schematic to illustrate a high shelf boost using a 100nF capacitor.
Perhaps you could tell me where you think the boost begins and ends?
Cheers
ian
From the circuit in the LTSpice simulation you showed I derived exact formulas if anyone is interested. (IF THE IMAGES DO NOT LOAD, HIT REFRESH IN YOUR BROWSER)
The transfer function is given by
So there is a zero at
and a pole at
The frecuency at which a certain attenuation ('Att') in dB occurs is given by
For the special case where both resistors are equal to a value R, the equation reduces to
Furthermore, if both resistors are equal and ATT = 3, which is the 3dB frequency, the equation becomes
So for Ian's circuit the 3dB frequency is at 3.75 kHz.
Please note that whatever equation you use the value of ATT must lie on the interval
which for the case of equal resistors is between 0 and 6 dB.
So lets say that both resistors are equal to 600 ohms and we want to make the shelf Attenuate 1 dB at 1 kHz, then we would need a cap of
Just for fun: Lets make a shelf with a maximum attenuation of 12 dB and a -3dB frequency at 1 kHz.
The maximum attenuation is given by
Solving for R1
If we choose R2 = 1K, then R1 is roughly 3K.
Now we can substitute these values in the big equation at the top with f0=1000 and Att=3 and solve for C
The simulator agrees, there is a small difference due to rounding but good enough for rock n' roll
