Creative SB G6/CS43131
Tubetec
Re: Creative SB G6/CS43131
Post by Tubetec »
Heres two averaged noise measurements from the SSL2 , same settings
first with the driver misbehaving , second with the driver working properly .
The other thing is with the driver misbehaving , the frequency response shows bumps within the audio band .
As you can see it makes a huge difference to the wideband measured noise results
Tubetec
Post by Tubetec »
and just for comparison the on the same page , the two measurements from the G6 ,
first with driver gone wonky , second working correctly ,
Tubetec
Post by Tubetec »
I found that the RTL latency software displays this same bump in the noise when the sample rate is changed , so that basically says the problem is not due to REW at all , its something to do with either the driver or Windows or both .
https://oblique-audio.com/rtl-utility.php
