Mic Fet booster with stepped HPF and line drive
Re: Mic Fet booster with stepped HPF and line drive
Parts Express stocks Dayton axial polypropylene in large values for crossovers and they're an excellent value and measure well but any large film cap tends to be microphonic.
Sorry, yes, I meant coupling capacitors. English is not my native tongue and I sometimes mess things up.mediatechnology wrote: ↑Fri Dec 27, 2024 12:59 pmI agree but don't you mean to say "coupling" (DC-blocking) rather than "decoupling?" (supply bypass)AnalogJoe wrote: ↑Fri Dec 27, 2024 10:28 am Electrolytics distort even when a small signal voltage drop is impressed across them, which makes them perfectly ok as decoupling caps if you place the cut-off frequency so low that the voltage drop across the cap is insignificant at audible frequencies, but if you use it as a filter with a higher cut-off frequency, they will have a significant voltage drop across them at audible frequencies.
I like the first bootstrapped FET input circuit better as it uses small value films.
The bootstrapped FET does seem like a better choice.
Ive never been happy with the sound I get from standard soundcard mic input to A/D convertor/monitor out .
Without any way to manage the bass hump its unusable for close miked sources ,
There is a lot to like about the Sennheiser circuit , its elegant in its simplicity and as the years go on you dont have to worry much about the coupling caps slipping in value . The five HPF positions provided by the TFE/Canford gets me very close to where I want to be sonically without the need for more complex eq ,
As the frequency range tests show the almost 90khz upper bandwidth limit of the SSL2 is unimpacted with the circuit in place ,
FreE-Q seems like an apt name for it .
I hope you guys have the chance to check out one or other variations on this theme,to suit your own taste ,
I have to add the original inspiration for a passive HPF/proximity filter at the front end came from P.J.Baxanadalls 1950's high quality pre amp design , as I mentioned already I have a CF based LDC tube mic with a 12 position passive HPF at the output , matching into hiz unbalanced , the results are nothing short of superb , were not talking 'coloured' or 'fuzzy around the edges' or the 'warm' tube sound , its absolutely pristine , upto the highest SPL's you can throw at it ,
The next step is to try the CF/HPF/buffer in an impedence balanced fashion , signal output of course remains signal ended , but we get the benefit of any cable induced noise being reduced signifigantly .
An LDC/CF mic can output 20 volts peak on loud sound sources , the Sennheiser MZA-14 buffer is limited to around 700mV before distortion rises to an unacceptable level , thats likely to be perfect for a good quality 48V powered condenser .
Attenuation of the CF could be used , but preferably not as it will spoil the low output impedence , if attenuation is required , its better done after the buffer, likewise with series/parrallel output transformer secondary being used to alter the gain structure and drive impedences .
What happens if we want to power not only the buffer and mic polarisation but run a tube HT supply off the same rail ?
Transistorised class A buffer with 125v-150v supply ? its well beyond even the 2N3055's voltage rating ,a high voltage mosfet seems more appropriate .
Id also like to try out one of the Klark Technik dynamic mic boosters ahead of the HPF ,
https://groupdiy.com/threads/cloudlifte ... 014/page-2
Some helpful hints here , I wonder did Abbey ever get around to re-doing his his fet boost circuit in a more flexible format ,
Your English is excellent - I've always thought it was your first language.
I found a few Mosfets circuit of interest here ,
https://www.tubecad.com/index_files/page0021.htm
Maybe the choke loaded source follower but using a transformer on the output .
The transformer at the input isnt much use .
Thank you for your kind words.mediatechnology wrote: ↑Tue Dec 31, 2024 3:03 pmYour English is excellent - I've always thought it was your first language.
Why do you need a transformer in a tube push-pull fashion? Compared with tubes, a big advantage of having N and P channel devices is that you don't need a transformer, there are no equivalent "P channel" tubes.Tubetec wrote: ↑Tue Dec 31, 2024 8:21 pm I found a few Mosfets circuit of interest here ,
Chokes with solid cores are also non-linear, which makes them distort.
The circuits you posted are very interesting and look fun, but I believe you can achieve better results with less exotic and conventional circuits that do not require inductive elements.
Some interesting stuff about FETs here ,
https://groupdiy.com/threads/comparison ... 559/page-6 ,
Its something a bit like that I had in mind for the output stage , but using step up transformer in place of the choke ,
output being taken either direct or via the transformer secondaries .
It seems pretty clear now from what I've read , with transformer/choke coupled output , there no need for a high voltage supply or Mosfets ,
Plenty of down sides to transformers , I know that ,
It does change the overload characteristic of an amp , having a transformer with current flowing in it and hence stored electromagnetic energy in the core ,which it can use on the peaks , like a back EMF.
Now of course we know transformers dont tend to distort well with heavy bass content , but on short term peaks or transients at mid or high frequencies it soft clips less abruptly than an amp with lots of NFB .
Its not so much an effect Im looking for ,more a graceful overload when the convertor is approaching 0DBFS ,
which under normal circumstances in recording your nowhere near , intentionally anyway .
Theres also the simplicity and the fact that you can swing four times the supply voltage across the output devices in push pull .
As we said complimentary pairs are fundamentally different devices , and usually a large amount of overall negative feedback is needed to iron things out , when an amp like that starts to overload the NFB can longer work as intended , everything goes hellter skelter .
Another downside of the class B push pull arrangement is the transistors are likely to need matching to some degree , or performance could suffer .
Perhaps its less of an issue with class a bias , as the transistors are always on .
