The main culprits, in most cases, for CM distortion are reversed biased PN junctions (like BJT colector-base junctions) which vary their capacitance non-linearly as their depletion layer (or region) changes in size as the voltage across the junction also varies, which creates distortion voltages as these non-linear currents flow through resistors. Balancing resistors create equal (or near-equal) voltage drops across the op-amp's differential inputs, which reduces distortion. Inverting amplifiers have near-zero voltage swing at the op-amp's input, hence the junction capacitance remains near-static and almost zero CM distortion occurs. Adding input protection diodes to an opamp amplifier makes the problem worse; Merlin Blencowe discusses some simple but effective solutions.
The article Merlin Blencowe wrote for ED Magazine a few years ago on reducing common mode distortion due to input protection diodes is:
https://www.electronicdesign.com/techno ... p-circuits
Balancing Resistors Reduce Voltage Follower Common Mode Distortion
Re: Balancing Resistors Reduce Voltage Follower Common Mode Distortion
I remember that article. Thanks for linking to it!
Woke is dead.
