Universal Tape EQ converter
Hi All,
I have accumulated a few NAB tapes over the year and playing them back is usually a bit of a pain - I use a Studer A80RC machine and involves swopping out the Reproduce channel cards (I could just swop the EQ plug ins but that would then involve setting up the cards again) and I was wondering if anyone has come across a line-level piece of equipment for transcripting a NAB (now IEC2) tape played back on a IEC1 machine, and vice-versa.
Come to think of it a device for the Reproduce side and the Record side would be even more useful, so one could record a IEC2 tape on an IEC1 Recorder, and again vice-versa.
Thoughts.
Thoughts.
Re: Universal Tape EQ converter
Hi Wayne,
Thanks for the reply.
I thought a bit about a digital domain answer but wanted to stick in the analogue domain if possible. Judging by the rush of replies, it looks like I will just have to switch replay amps when necessary.
Cheers.
Mike
Cheers.
Mike
Do you have tables of the EQ values at various frequencies that could be used to compare them?
The RIAA EQ that I have on one of my boards is switchable from RIAA to Inverse RIAA.
If you could figure out what the differences in curves amounted to and could reconfigure the RIAA network to switch between tape standards you could have a network that would go from either standard to the other.
I discuss it at Lathe Trolls: https://www.lathetrolls.com/viewtopic.php?f=9&t=5848
Further research (lurcing) brought the enclosed PDF to light from MRL which makes things a bit easier.
Page 8 is a real nugget of information. As the author (Jay McNight) points out in the text, you can reverse the columns of "Recorded Frequency" and "Playback Frequency" for those tables at the same speed by simply changing the polarity of the "Playback Level" column.
Regards
Mike
Regards
Mike
Although software, U-He Satin has a bunch of repro modes available with visual feedback over the frequency curve. Can be further manipulated with the tape machine side of the plugin (it's a tape sim after all).
That's what I was looking for.fredbloggstwo wrote: ↑Fri Oct 29, 2021 2:32 pm Further research (lurcing) brought the enclosed PDF to light from MRL which makes things a bit easier.
02-209 MRL Choosing and using tapes.pdf
Regards
Mike
In CoolEdit I think I can setup a filter based on entering the levels and frequencies with text.
Haven't done it in awhile but I recall doing that for RIAA and I-RIAA.
You might also be able to do that in Audacity.
Hi all,
just to round this subject off, I took the useful tables from Jay McNight's paper and put them and their counterparts into a spreadsheet and thought I would share it. I also converted the VU dB levels to voltage in case you prefer them that way. If anyone finds any glaring mistake, please let me know.
Interestingly, it also implies that you could take a 7.5 ips calibration tape and interpolate the tables for playing it at 15 ips and thus EQ beyond 20 kHz if you so wish.
Kind regards
Mike
Kind regards
Mike
- Attachments
- EQ conversion tables V4.xlsx
- (24.71 KiB) Downloaded 697 times
Thanks for sharing the spreadsheet.
I gave my alignment tapes to a neighbor who does restorations and I'll forward this to him.
