"MS Mini" Basic Mid Side Board
Post by mediatechnology » Wed Aug 25, 2021 7:48 pm
Update September 9, 2021. The construction thread is located here: The construction thread for the Mid Side Mini is located here: viewtopic.php?f=7&t=1272
I've had a basic MS board on my list to replace the original I did over a dozen years ago.
The "MS Mini" incorporates the Mid Side gain offset capability of the MSII.
Using jumpers, Mid Encode level can be attenuated 6 dB [(L+R)/2] and an offset gain of +6 dB applied on decode to maintain MS ratio.
Using a jumper and an IC change (IC6 1240 or 1246) Side Encode level can be boosted 6 dB with a decode offset of -6dB.
Gain offsets in the Mid, Side or both Insert Sends present more-balanced levels to outboard gear.
Side is particularly level-challenged often being 10-20 dB below Mid.
The MS-Mini's decoder, identical to the MSII also prevents M+S and M-S from producing 2L and 2R.
This avoids having to incorporate a -6dB stage to maintain unity gain.
MS-Mini PC Layout
The board is about 3.7" by 2.75".
I'll be ordering them in the next day or so and should have a small run in about 10 days.
Covidland (The Movie) Part 1: Lockdown https://banned.video/watch?id=615f96b3aa816336dbd21792
A voice-over with Orson Welles: "What Is It That You Want?": https://waynekirkwood.com/content/Orson ... u_Want.mp3
Americas Frontline Doctors Lawsuit Motion For Preliminary Injunction Of Covid-19 Vaccine Emergency Use Authorization: https://waynekirkwood.com/images/pdf/Am ... zation.pdf
Re: "MS Mini" Basic Mid Side Board
Post by mediatechnology » Sun Aug 29, 2021 3:05 pm
This is the schematic for the "Mid Side MIni."
Mid Side MIni Compact MS Encoder/Decoder
Post by emrr » Wed Sep 08, 2021 7:42 am
Nice
Post by Gold » Wed Sep 08, 2021 1:25 pm
I still have a pile of the V1 PCB's that I get good use out of. This is a nice addition to the line.
Post by mediatechnology » Wed Sep 08, 2021 3:41 pm
Thanks guys!
I'm expecting a small run of boards to arrive in the next hour or so.
Post by mediatechnology » Wed Sep 08, 2021 4:24 pm
Just in...
Let's see if it runs.
Mid Side Mini PC Board
Post by mediatechnology » Wed Sep 08, 2021 8:19 pm
Works great!
MS Mini PCB Assembled
Left > Right Crosstalk Full Encode/Decode
MS Mini Crosstalk L Into R
The full encode/decode 20 kHz unweighted noise level is about -96 dBu.
The dynamic range is 123 dB with +/-15V supplies.
MS Mini Noise Level 20kHz BW Full Encode Decode
