Page 1 of 1
THAT5263 Dual Digitally Programmable Gain Controller
Posted: Fri Oct 30, 2015 11:10 am
October 30, 2015. THAT Corporation, a leading provider of high-quality audio ICs, today announced the availability of the THAT5263 - a wide-range digital preamplifier controller IC intended for use with low-noise differential analog audio preamplifiers. The 5263 operates from ±5 to ±17V analog supplies, offers 3dB steps from 0 to 51dB gain, and supports input signals up to +29.6 dBu.
THAT 5263 2-Channel Digitally Programmable Gain Controller:
http://www.thatcorp.com/5263_Digital_Pr ... _ICs.shtml
THAT 5263 2-Channel Digitally Programmable Gain Controller datasheet:
http://www.thatcorp.com/datashts/THAT_5 ... asheet.pdf
THAT5263 Block Diagram
Re: THAT5263 Dual Digitally Programmable Gain Controller
Posted: Sat Oct 31, 2015 10:54 am
by emrr
Bench report soon?
Posted: Sat Nov 07, 2015 5:31 pm
Bench report soon?
Come to think of it that would be fun.
Posted: Sat Nov 07, 2015 6:36 pm
by brianroth
Interesting timing....
Awhile back, we ended up with e Genex box with 48 mic preamp channels which are gain controlled via an "Ethernet" link into a PC app (protocol? who knows...). Main reason the box was sold was for the DSD outputs. Paul Wolfe designed the front end, but the remainder is a mystery.
We needed MADI outs for a fledgling mobile rack, but the Genex box only supports 32 MADI channels.
Soooooooo..I began looking for off-the-shelf ways to remotely wiggle the gain of a bunch of preamps located on a stage.
Bri
Posted: Sat Nov 07, 2015 8:36 pm
For your application Brian you also might look at using one of the THAT5263 (or 5171, 5173) attenuator ICs in the "switcheroo" Universal input found here:
viewtopic.php?f=6&t=514
It goes from +60 to -60 dB gain on one "knob" and input connector.
The DG413s are controlled by GPOs in the 5173 to make the switching seamless.
In attenuation mode the INA is a voltage follower with the 5173 attenuator after the follower.
In gain mode the 5173 attenuates feedback in the conventional topology.
With 30V supplies the input overload point is around +27 dBu so line input pads are not needed.
The THAT5173 and 5263 gain steps may be too "chunky" and a 1 dB or 0.5dB interpolator could be added to the output buffer or done in DSP.
The THAT5263 looks ideal for this circuit.
A Universal Input Using the THAT1570 and 5173.
