What happens is, every now and then upon power-up, a single channel of one of the 4 channel DAC's will start sending out full-rail voltage (5v), or nothing, depending on the data being sent to it. Under normal conditions, the maximum DAC output is 4.096v. The other three channels of the DAC continue functioning fine, which leads me to believe that it's a problem on that particular DAC channel's output, not the input. It seems like the output amp on the DAC chip is failing. The fact that the channel still responds to data seems to indicate that the resistor string of that DAC channel is still functioning, but the amp is shorting internally and sending out the full supply voltage of 5V.
I'm wondering if the wimpy little output amp on the DAC doesn't like being connected to the -3.7V CV bias, and may need to be isolated somehow. In the datasheet it says:
and earlier says:7.6 Application Examples
The MCP4728 device is a rail-to-rail output DAC designed to operate with a VDD range of 2.7V to 5.5V. Its output amplifier of each channel is robust enough to drive common, small-signal loads directly, thus eliminating the cost and size of external buffers for most applications. Since each channel has its own configuration bits for selecting the voltage reference, gain, power-down, etc., the MCP4728 device offers great simplicity and flexibility to use for various DAC applications.
Or possibly if the LM7912 regulator that's providing the bias voltage (who's supply voltage is derived from the -18V leg of the PSU) is sending a spike upon power-up.7.2 Layout Considerations
Inductively-coupled AC transients and digital switching noise from other devices can affect DAC performance and DAC output signal integrity. Careful board layout will minimize these effects. Bench testing has shown that a multi-layer board utilizing a low-inductance ground plane, isolated inputs, isolated outputs and proper decoupling are critical to achieving good DAC performance.
Separate digital and analog ground planes are recommended. In this case, the VSS pin and the ground pins of the VDD capacitors of the MCP4728 should be terminated to the analog ground plane.
Here's an overview schematic of my circuit (sorry for the cut-off image - try reloading in a new window). Any thoughts?
