Parametric eq with only two opamp sections
Hello,
Just registered on this forum and thought I should make a small contribution - perhaps it will be of interest to some of you.
Parametric eq's (with independently variable centre frequency, bandwidth/Q and cut/boost) are by large created using a state-variable filter consisting of to integrators and a summing section. This requires a total of four op-amp sections.
But a parametric eq section can also be realised differently. I am aware of the early "Twin-T" designs by Sontec etc but it can also be realised with a Wien-bridge filter. I first came across this in design for Crest Audio done by the late Joe Petrucelli. His version had switched Q but could be altered to variable. Later I came across a similar implementation in the Audient ASP range by David Dearden. David is still around and he gave me his comments as follows:
Looking at the ASP8024 schematic for the first time since around 1997, it is basically a WEIN bridge topology which was in common use in all Soundcraft consoles and also in by various other manufacturers in the 80's and 90's. However, they were all fixed Q with the Q and amount of boost/cut heavily dependent. The normal situation was to set the boost/cut to around +/-15db by adjusting the ratio of the capacitors (which I think was around a 2:1 ratio) and accept that the Q would be around 1.3. Both mine and JP's version have equal value capacitors.
I wonder whether it was JP or Chas Brooke at BSS came up with the elegant way of achieving independence between boost/cut and Q by simultaneously changing the gain of the boost/cut invertor opamp and the Wien opamp with a single resistor? Sadly, we will not be able to ask JP, but if I see Chas I will ask him.
Re: Parametric eq with only two opamp sections
Thank you for joining and posting cuelist!
You might want to try and re-upload the image.
Looking forward to seeing it...
I just had a chance to look at this.
I think I've seen something similar to it and will look for it.
Yes the SVF topology can provide complete independence between EQ parameters. (I sold a SVF based parametric EQ kit in 1979.)Cuelist wrote: ↑Sun Jun 21, 2020 9:49 amHello,
"John" Petrucelli, RIP a good friend who is missed. (He was also the "P" from APB consoles, founded by a few other ex-Crest/Peavey employees).But a parametric eq section can also be realised differently. I am aware of the early "Twin-T" designs by Sontec etc but it can also be realised with a Wien-bridge filter. I first came across this in design for Crest Audio done by the late Joe Petrucelli.
viewtopic.php?f=11&t=855&p=10070&hilit= ... lli#p10070
We used fixed Q wein bridge mid-sweep EQ at Peavey back in 90s, our topology used one op amp per EQ band. We also tooled up a custom pot where the two variable Rs for frequency control were done with a single pot section (common wiper shorting across two screened resistive tracks on single wafer.) This allowed a single concentric pot to vary both boost/cut and center frequency
From glancing at the schematic I'm not so sure the Q is completely independent but easy enough to prove with sim (by someone else).I wonder whether it was JP or Chas Brooke at BSS came up with the elegant way of achieving independence between boost/cut and Q by simultaneously changing the gain of the boost/cut invertor opamp and the Wien opamp with a single resistor? Sadly, we will not be able to ask JP, but if I see Chas I will ask him.
Audient_ASP_mid_eq.pdf
It's nice to be nice.
Here's a SIM I did on this some years back on the Crest Century V12 which has variable Q in this topology:
Looks to me like Q and gain are not interacting too much.
Here's the schematic (also a JP design):
The interaction doesn't look to be enough to be of any real consequence.
Thanks for posting this!
Thanks for the sim... That is definitely good enough to call the Q independent. I've seen and used Wein bridge EQ, but not with that extra op amp buffering the high impedance node.Cuelist wrote: ↑Sat Jul 04, 2020 10:39 amHere's a SIM I did on this some years back on the Crest Century V12 which has variable Q in this topology:
Crest_Century_V12_mideq_SIM.pdf
Here's the schematic (also a JP design): Crest_Century_V12_mideq.pdf
Back in the 80s I put full parametric EQ in one console input strip (LOFT) but I used more conventional SVF topology... the high and low bands had switchable shelving that made the Q adjustment more than a little weird.
FYI - The Q-range on that Crest EQ is 0.7 to 3.0
