Transistor Vbe Matching Using A Commutating Chopper-Based Circuit
Re: Transistor Vbe Matching Using A Commutating Chopper-Based Circuit
Post by mediatechnology » Wed Oct 07, 2020 2:01 pm
I finally got the Vbe Matcher off of a Protoboard by moving it to Vectorboard.
It's been awhile since I did point-to-point Vectorboard.
The connections across the top are Power, 'Scope Monitor Out (filtered), Output to A/D, 1.5 mV P-P Calibration signal, 15V Trigger output.
The two jumpers and shunts switch the test socket from NPN to PNP.
There are two rows in the test socket.
The right-hand row is for CBE pinout transistors.
The left-hand row is for BCE pinouts.
The clip is to thermally equalize the test transistors.
A pair of BD139 BCE pinout transistors:
A 2SB737 pair:
One more project I can check off the list...
It's been a productive few weeks.
Post by mediatechnology » Thu Oct 08, 2020 12:54 pm
JR. wrote:
Sun Dec 22, 2019 9:38 am
If you add a 50k or so resistor from the junction of the two emitters to ground that would prevent potential reversed junctions from zenering when switched for the wrong polarity.
I added D1-D4 to clamp Ve.
Not only for the reason JR gives but also to reduce recovery time for when both devices are removed from the test socket.
Without D1-D4 Ve goes to the rail when Q1 and Q2 are removed.
