I have some new op-amps in stock;
4558 Raytheon .39ea $35.00/100
NE 5532's Fairchild .39ea $35.00/100
Also bear in mind I also stock 24 Awg PTFE/Teflon stranded wire, DPDT 12V Relays and LM 3914's too.
Steve @ Apex Jr
www.apexjr.com
New Op-Amps in stock
Re: New Op-Amps in stock
Thanks for posting Steve.apexjr wrote:I have some new op-amps in stock;
Steve @ Apex Jr
http://www.apexjr.com
I want to point out that the DPDT relays Steve is referring to are the Aromat DS2Y-S-DC12V used in the Pico Compressors:
http://www.apexjr.com/components.html#Relays
The LM3914 are used in the GR Meters:
http://www.proaudiodesignforum.com/Pico ... ter_10.htm
http://www.proaudiodesignforum.com/Pico ... ter_20.htm
Would those relays be good for a mic level signal for use in a pad?
Thanks!
Bruno2000
Thanks!
Bruno2000
What Roger said. They are sealed as well and may be gas-filled IIRC.
Thanks guys, I just ordered a bunch for the "Wayne's Mic Pre" project!
Bruno2000
Bruno2000
