This is not the case. So far the output has always been full on. It's hard wired cause I don't have a master fader/pot yet.JR. wrote:Sorry for these vague comments, but I haven't followed this project closely.
Hearing hum when output is turned down, but not while turned up, if not just other noise masking the hum, may be a ground referencing issue between master local ground and output ground. If the output feed is properly differential from the master it should be silent when turned down. I'm not sure which schematic is in use, but if it's the one with simple follower buffers, perhaps they could be used to provide differential between master and sundry output grounds.
Not sure if I understand what you mean here but let me explain how I did the grounding.JR. wrote:Also, if the gauge of the ground wire is making an audible difference that suggests to me there is noise current flowing in that wire that is being reduced. So that ground wire is not just a reference but perhaps part of the ripple filtering path, so voltage will not be the same along that path.
In this project , every channel, master module, monitor etc. etc. has it's own ground wire to a star ground point (bus bar).
Take for example the channel input module. It has a ground plane for all power decoupling caps and on the other side a star ground for all audio ground. Ground plane and star ground meet at one point on the pcb from which the thick ground wire originates which goes to the bus bar. The bus bar goes to the PSU (which is in a separate case btw) 0V and ties to the chassis in the PSU case. The chassis ground from the mixer goes to the chassis ground in the PSU. All XLR pin 1 go to chassis ground from the mixer.
Relay, lamp and LED power has it's own ground wire all the way to the PSU where it connects to chassis ground AND to 0V from the PSU.
