Recommended Test Procedures for Op Amps, Intersil AN551
This application note from Intersil shows their recommended test circuits for op amps.
Included are Offset Voltage, Input Bias Current, Input Offset Current, Power Supply Rejection Ratio, Common Mode Rejection Ratio, Output Voltage Swing, Slew Rate, Full Power Bandwidth, Rise Time Fall Time and Overshoot, Input Noise and more. The simple relationship between slew rate and power bandwidth is discussed.
https://www.proaudiodesignforum.com/ima ... _AN551.pdf
