MCI console automation retrofit
brianroth
Post by brianroth » Wed Jul 31, 2019 5:34 pm
Wayne, I didn't know where to post this....please move the thread elsewhere if it makes better sense.
IIRC from the dusty corners of memory that you were involved with the design of an automation system retrofit for the MCI JH-50. Presuming my memory is correct, I'm curious about any details, availability of any components, etc.
Thanks!
Bri
www.BrianRoth.com
Re: MCI console automation retrofit
Post by mediatechnology » Wed Jul 31, 2019 7:17 pm
Brian - That was Russ Whitaker of Dallas Sound Lab now MediaTech Institute. I was only involved peripherally. IIRC it was a JH-500 Automation to Midi Interface.
"Planned Parenthood Admission In Deposition Regarding Fetal Organ Sales" https://proaudiodesignforum.com/content ... ission.mp4
brianroth
Post by brianroth » Wed Jul 31, 2019 8:06 pm
OK, I guess I'm still in the weeds! lol
I still run across MCI JH-600 series desks "in the wild", and with the automated version, when the JH-50 system craps out, important features are kaput. Fader mute is the most important, but solo in place and fader grouping are quite useful.
I have a client who still uses the fader automation when mixing, although his JH-24 is retired and he works with an Alesis (?) 24 track hard disc recorder or a DAW. He uses two tracks in the DAW/whatever to do read/write/update, and he has a fairly busy amount of clients.
When I was working at A-Mc Advertising in the 1980's, a third-party (I seem to recall they were in Atlanta) sold a drop-in CPU card that worked with the digitizer boards.
Bri
www.BrianRoth.com
Post by mediatechnology » Thu Aug 01, 2019 5:29 am
I recall Russ building replacement digitizers.
You might want to talk to Russell and see what happened to his prototypes. https://mediatech.edu/
Russell might be a good service lead for you.
Last time I saw him he was doing most of it himself over several locations.
I think once you had circuitry to mux all the faders you could probably run the entire automation system on a Rasberry Pi and have Midi out with an HDMI console display.
Speaking of video displays for console automation...
Someone needs to make an LCD replacement for the SSL 4000 and 6000 inbuilt monitor.
