Post by billshurv »
I think it is very safe to say that this is a torture test and most MC users will not have anything like that level of mains fields anywhere near their turntables. I'll take two!
KMN
Post by KMN »
Wow. That is impressive, especially after learning about the the details of the hum torture chamber you are running it in. That's a lot of gain and a lot of cable with all that stray field around. I think I might need one too.
Very nice!
Looks good Wayne. I think my DL103 into your MM preamp with a Lundahl 1:8 stepup is about the same. I don't have FFT setup yet so I can't quite do an apples to apples comparison.
I've been quite happy with this setup. I think I have a resonance around 10K. I underdamped the cartridge because to it sounded constrained fully damped. It's probably due to that.
Audio1Man
Post by Audio1Man »
Hi Wayne
Is the “HUM” Electrostatic or Magnetic? What is the difference in FFT by wrapping the pickup in Alum foil vs putting it in a steel paint can and closing the lid? What is your area lighting type? Incandesce, fluorescent tube or switching fluorescent / LED type?
Duke
Thanks everyone!
It's magnetic. Aluminum does nothing.
Lighting is all LED and it occurs with them off.
The hum hot spot are the huge transformers, running with a fair degree of core saturation, in the APC UPS units.
My magnetic hum sniffer (a telephone pickup coil and battery-powered R-S amp) also nulls to the exact same angle in the field.
It hums like a b*tch near the APCs.
Guitar pickups are also a problem in this room as well as the spring reverb.
Quite a bit comes from ingress into the DL-103 itself.
I'm not worried about it: In this particular case you wouldn't want to monitor at a level where you could actually hear it.
If the needle were to drop or the platter start spinning the monitors would be destroyed.
I actually ran gain up in a deep fade to listen to the noise floor, couldn't hear it beneath the surface noise, and quit afraid I would run into the intro of the next cut.
I'm not going to spend any time on it right now because as a practical matter its so deep in the mud as not to matter.
I do want to get some mu-metal to quieten the spring reverb and I'll try lining the metal Hammond box with it.
Not sure I can do much to shield the DL-103.
First off, thanks to show all this nice work.
I do want to get some mu-metal....and I'll try lining the metal Hammond box with it.
I am very interested about this.
Audio1Man
Post by Audio1Man »
Wayne
What about placing the BIG TX into a 5 Gal steel paint can? This may give you another 10-20dB reduction.
I need to pickup a clean paint can.
It will fit in a 1 gallon.
I usually keep those but used the last ones for some stain.
brianroth
Post by brianroth »
How about using a Hoffman "screw cover pull box" without the knock-outs as an outer shell? Widely available from electrical supply distributors. Heavy gauge steel.
I'm thinking about getting a decently sized one...maybe 8x8 or larger....and poking Neutrik XLR and TRS jacks into the side along with some binding posts for DC power. Then I can sit my solderless protoboards, perfboards, new PC boards inside and have some magnetic shielding.
Bri
www.BrianRoth.com
