EEQ-12 Elliptic Equalizer Construction Documents
Post by mediatechnology » Sat Oct 28, 2017 2:44 pm
This thread documents construction of the EEQ-12 Elliptic Equalizer.
Update March 9, 2019: Assembly and Test Instructions: https://ka-electronics.com/images/pdf/E ... 0919_1.pdf
Elliptic Equalizer EEQ-12 PC Boards: https://ka-electronics.com/shop/index.p ... search=EEQ
Schematics:
Sheet 1: https://www.ka-electronics.com/images/p ... heet_1.png
Sheet 2: https://www.ka-electronics.com/images/p ... heet_2.png
Circuit Description: viewtopic.php?f=6&t=828&start=46
Mouser Project Manager BOM for the EEQ-12 Elliptic Equalizer 12V Relays: https://www.mouser.com/ProjectManager/P ... f06782454f (includes THAT and NJR ICs)
Mouser Project Manager BOM for the EEQ-12 Elliptic Equalizer 24V Relays: https://www.mouser.com/ProjectManager/P ... 470f9f152e
24V relays are recommended if the available relay supply is >24V or the relays are powered from the +/-15V audio supplies.
Board Stuffing Diagram:
https://www.proaudiodesignforum.com/ima ... ut_800.jpg
"Antifa puppetmasters to engineer 'patriot' slaughter of Leftists to spark violent uprising against conservatives" https://www.naturalnews.com/2019-10-20- ... tists.html
Re: EEQ-12 Elliptic Equalizer Construction Documents
Post by mediatechnology » Thu Nov 01, 2018 4:04 pm
Blog post from Ian Stewart on Elliptic EQ: http://ianstewartmusic.us/blog/center-that-sub
KA-Electronics EEQ-12: Among the minimum phase alternatives, the KA-Electronics EEQ-12 is the standout. This analog DIY device, designed and sold by Wayne Kirkwood, manages a 12dB/octave slope without the negative affects of phase shift usually associated with higher order filters. In a nutshell, he does this by compensating with cleverly designed all-pass filter network. If you’re interested in further reading on this device, you can see the design process here. Worth noting, the EEQ-12 tested uses a cutoff frequency of 150Hz rather than the 100Hz setting chosen for all other processors. Even so, it achieves better separation in both the frequency and stereo spaces, and with less phase shift to boot, than any of its 6dB/octave minimum phase elliptical EQ cousins.
Post by mediatechnology » Sat Mar 09, 2019 7:28 am
