Im really bad at checking forums that I post on. But as far as the face plate, I got vintage potentiometer plates from ebay and all the little custom stick on signs came from here: https://www.legend-plates.com/
It ended up being cheaper than any quote I got to have the panel engraved.
MTC-MS-II Mid Side Matrix Construction Information
Re: MTC-MS-II Mid Side Matrix Construction Information
Great work Matty!
Here are some pics of my build which is an integration of the MTC-MS-II and the EEQ. Front pannel is temporary, hence the shoddy symetry and text. But it sounds great! Five square switches are (L to R): Enc, Dec, M/S, Mid, Side bypasses.
I used Lorlin 12 step(11 actually) switches for Width and Tilt because they were less expensive than Elmas. I used 9k resistors and that is quite functional, but I will experiment with R values at some point to maybe find some "sweet spots".
Thanks again Wayne for your help!
Beautiful work!
Where did you source the EAO-looking switches?
I saw those somewhere else recently as well and they look really nice.
Thanks Wayne!
The "EAO" lookalikes are from ebay. (Just search for: push button switch led 16mm)They are not the same solid feel as EAOs, but they work fine and they are about 1/10th the price of the reel thing.
One thing I discovered when wiring them to the MS2, is that they are advertised as LED switches but they are NOT. When I hooked them up to the MS2, the leds would not work. After opening one, I discovered they are (tiny)incandescent bulbs. But it was easy to replace them with LEDs.(3.5mm) So now they light-up as expected.
Wow... Beautiful work, kudos Matty and Sylvain!
I couldn't resist sharing as well. Thank you all for your help and guidance, It turned even out better than expected!
I used the MTC-IGFO, MSII, and 2 Insert Switcher boards to create this Master Console, as well as a velleman K8042 kit for powering the insert switcher relays. Elma Rotary Switches for gain, width, and tilt, NKK push buttons (and 3 position switches for Filters), and front panel + case from Front Panel Express. It's very quiet, clean, and does everything that I need to... and more. I'd be happy to answer any questions or assist if I can be of help!
Brian
Brian
Thank you for sharing Brian. Nice work!
Want to finish mine?
Those of you that want referrals to build stuff chime in.
I'm always getting asked.
Thank you!
I was supposing more of an online "tech support" more than in person building
As building is more of a hobby, my limited expertise and days (weeks) of troubleshooting may not be suitable in the wild...
Wow!
Very nice work all arround Brian. Nice front panel too!
I hope to evolve mine into something like yours someday with the i/o matrix and igfo.
I like those small square push button switches. Might I ask you who makes those?
Sylvain
Sylvain
Thank you for the kind words Sylvain!
I used NKK's HB Series of Illuminated switches -> https://www.mouser.com/ProductDetail/nk ... cycode=USD
Brian
Brian
Thanks Brian!
I was looking for something like that for another project.
Sylvain
Sylvain
