Re: Phono Transfer System
Thanks!, I'm glad you are familiar with these EVMs. I looked at the pcm4204evm guide and the schematic shows the currently blank spots for the possible caps. It looks like it wants electrolytics. Could film caps work? This is for dc blocking, correct? Schema also shows an R in parallel with the cap. Both have undetermined values?? What vdc and uF should I go for? I would prefer to use caps on the evm and then jump the connections on the MM phono. Thanks again.
The PCN4202 EVM does want electrolytics for DC blocking.
I agree that it would be best to add the caps to the EVM.
The input impedance is low - around 1K - so you would need at least 47 uF.
The parallel resistors jumper the caps when they are not installed so you will need to remove them.
A 25V cap should be sufficient.
Thanks, 1k is low so yes I will start with 47uf, impedance mismatch shows up in either rolled off highs or no bass, I'll experiment if 47uf doesn't work. I have a bunch of 47uf 16v, will those work? So the plan is to jump the c4-c5, c24-c25 on the MM then remove any jumpers or Rs on the evm and replace with polar lytics, correct?
47 uF is probably the minimum you would want to use. Yes, jump C4, C5 et al and remove jumper resistors on the EVM. Replace with polar caps having plus terminals pointing to the OPA1632.quattro64 wrote: ↑Mon Jul 17, 2017 11:22 am Thanks, 1k is low so yes I will start with 47uf, impedance mismatch shows up in either rolled off highs or no bass, I'll experiment if 47uf doesn't work. I have a bunch of 47uf 16v, will those work? So the plan is to jump the c4-c5, c24-c25 on the MM then remove any jumpers or Rs on the evm and replace with polar lytics, correct?
Cool, I'll start with these and then let you know how it goes. Thanks again!
After reading through the pcm4222evm thread I see that without the caps the opamps are forced to run in class A bias. Due to the dc they're required to sink? Anyway I might like that, at least to try it out. Maybe set it up on a switch. Seems there is more input R on the pcm4204evm compared to the pcm4222 so 47uf is probably fine. Also, it seems since it is 4 channel it requires more continuous current to run, 0.5mV versus the 0.2mV of the 4222. So I wonder if my regulated 1.5 amp supply will be able to run both the flat mm phono and the 4204 at +-15V?
I haven't found that there is any distortion penalty for not having coupling caps with the op amps in class-A having to sink current from the EVM. You'll lose a little headroom since about 2 mA of THAT1240 output current can't be used for signal. The 1240s Isc is 25 mA typical.quattro64 wrote: ↑Tue Jul 18, 2017 5:09 pm After reading through the pcm4222evm thread I see that without the caps the opamps are forced to run in class A bias. Due to the dc they're required to sink? Anyway I might like that, at least to try it out. Maybe set it up on a switch. Seems there is more input R on the pcm4204evm compared to the pcm4222 so 47uf is probably fine. Also, it seems since it is 4 channel it requires more continuous current to run, 0.5mV versus the 0.2mV of the 4222. So I wonder if my regulated 1.5 amp supply will be able to run both the flat mm phono and the 4204 at +-15V?
I wouldn't recommend any kind of switching since it is guaranteed to click.
47uF/1K, which is really 23.5uF/2K differentially with the PCM4202EVM, works out to be 3.4 Hz.
The flat preamp pulls very little current usually about 8 mA per channel. The maximum should be no more than 20 mA/per channel.
Thanks, I will be leaving 2 channels as is to experiment, the others I modded with the 47uf caps. Whichever one sounds best will win so no switches. Also it is quite easy to use the 'schematic for standard op amps' in the pcm4222 pdf to bypass its front end completely and roll op amps, or use transformers connected directly to the 'loops'. Lots of things to try and If I do anything crazy I will post in the pcm4222 thread. Both your mm phono and the analog section of the adc work well with 15v so that is convenient. Still working on the PSs so will post more when I have something exciting to talk about.
The PTS system for Josh Bonati was buttoned up this past weekend. I'll install it this week. The remote box with the transformers is for a Denon DL103 that is going on the lathe. The other trasformerless pre is for an SL1200. The remote pre's take too long to hand build. FPE offered custom make extruded aluminum enclosures. As soon as the remote boxes are sorted out for easy assembly I'll be offering builds for sale.
Great work Paul!
Glad to see the metal hoods on the D connectors.
I used a DB-9 instead of XLRs for compactness and a regular plastic backshell can be an ingress point for hum.
Since I didn't have a shielded one I lined it with aluminum foil and brought the foil out so the clamshell grounded it to the connector body.
The foil made a huge difference.
I still have some 9 pin metal hoods sitting in my Mouser cart when I decide to do it proper.
I'm still learning Front Panel Designer.
I think custom-made cases will make preamp assembly a lot easier.
