Phoenix Connector Terminations
Post by mediatechnology » Mon Apr 09, 2018 7:32 am
I terminate the shielded twisted pair to three pin male header connections:
Use a multi-pin male header for connections to Phoenix connectors.
That makes connecting and disconnecting the Phoenix connections easier.
SOCIAL MEDIA PLATFORMS should advance FREEDOM OF SPEECH. Yet too many Americans have seen their accounts suspended, banned, or fraudulently reported for unclear “violations” of user policies. No matter your views, if you suspect political bias caused such an action to be taken against you, share your story with President Trump.
White House Tech Censorship Reporting Link: https://whitehouse.typeform.com/to/Jti9QH
BANNED VIDEO - UK Police Escort A Muslim Mob To ATTACK Tommy Robinson:https://www.newswars.com/censored-video ... n-england/
Re: Phoenix Connector Terminations
Post by JR. » Mon Apr 09, 2018 3:20 pm
I always thought Phoenix connectors were screw capture loose wire. like Image
That almost looks like an amp/molex whatever header.
Post by mediatechnology » Mon Apr 09, 2018 3:26 pm
They are Molex Centigrid-III headers.
You insert the header into the Phoenix connector and use it as a ferule.
If the crimp tools for Molex KK or Centrigrid-III weren't $400 each I would use them.
Phoenix are more DIY-friendly.
Post by Gold » Mon Apr 09, 2018 3:52 pm
You can use a generic barrel crimper for Molex KK. So more like $20 on the bay. I’m not a big fan of Molex KK. When the connector is seated it still can move around a bit. That makes me nervous. I love the Phoenix connectors. I replace Molex KK with phoenix connectors whenever I can. The relay switcher I have used the type above where the wires are secured by screws to the female part of the connector.
Post by Gold » Mon Apr 09, 2018 4:02 pm
I get ferrules from McMaster-Carr. They are much less expensive than Mouser for some reason.
https://www.mcmaster.com/?m=true%20Forc ... s/=1ccblw5
I use a Wiha crimp pliers
https://www.wihatools.com/softgrip-crimping-pliers
Post by JR. » Mon Apr 09, 2018 4:14 pm
Gotcha,,, neater and faster than tinned wire leads for bench work.
Post by mediatechnology » Mon Apr 09, 2018 4:37 pm
I'm not crazy about the Molex KK either.
I've had to repair bad crimps in a lot of commerically-produced gear using them.
I started using the headers for my test jigs.
Post by Gold » Mon Apr 09, 2018 4:50 pm
If you leave the wire bare the strands spread when you tighten the screw making poor contact. If you tin the wire it becomes brittle and easily breaks. The ferrules allow good contact and provide strain relief.
Post by mediatechnology » Mon Apr 09, 2018 5:08 pm
And if you do either of those things more than once the conductors look really torn up and mangled.
