MTC-MS-II Mid Side Matrix Construction Information
Matty-T
Re: MTC-MS-II Mid Side Matrix Construction Information
Post by Matty-T » Tue Jul 10, 2018 10:19 am
Im really bad at checking forums that I post on. But as far as the face plate, I got vintage potentiometer plates from ebay and all the little custom stick on signs came from here: https://www.legend-plates.com/
It ended up being cheaper than any quote I got to have the panel engraved.
Sylvain
Post by Sylvain » Sat Aug 11, 2018 10:10 am
Great work Matty!
Here are some pics of my build which is an integration of the MTC-MS-II and the EEQ. Front pannel is temporary, hence the shoddy symetry and text. But it sounds great! Five square switches are (L to R): Enc, Dec, M/S, Mid, Side bypasses.
I used Lorlin 12 step(11 actually) switches for Width and Tilt because they were less expensive than Elmas. I used 9k resistors and that is quite functional, but I will experiment with R values at some point to maybe find some "sweet spots".
Thanks again Wayne for your help!
Post by mediatechnology » Sat Aug 11, 2018 11:40 am
Beautiful work!
Where did you source the EAO-looking switches?
I saw those somewhere else recently as well and they look really nice.
Sylvain
Post by Sylvain » Sat Aug 11, 2018 2:33 pm
Thanks Wayne!
The "EAO" lookalikes are from ebay. (Just search for: push button switch led 16mm)They are not the same solid feel as EAOs, but they work fine and they are about 1/10th the price of the reel thing.
One thing I discovered when wiring them to the MS2, is that they are advertised as LED switches but they are NOT. When I hooked them up to the MS2, the leds would not work. After opening one, I discovered they are (tiny)incandescent bulbs. But it was easy to replace them with LEDs.(3.5mm) So now they light-up as expected.
benewell
Post by benewell » Thu Sep 06, 2018 12:07 pm
Wow... Beautiful work, kudos Matty and Sylvain!
I couldn't resist sharing as well. Thank you all for your help and guidance, It turned even out better than expected!
I used the MTC-IGFO, MSII, and 2 Insert Switcher boards to create this Master Console, as well as a velleman K8042 kit for powering the insert switcher relays. Elma Rotary Switches for gain, width, and tilt, NKK push buttons (and 3 position switches for Filters), and front panel + case from Front Panel Express. It's very quiet, clean, and does everything that I need to... and more. I'd be happy to answer any questions or assist if I can be of help! :)
Brian
Post by mediatechnology » Thu Sep 06, 2018 12:18 pm
Thank you for sharing Brian. Nice work!
Want to finish mine?
Those of you that want referrals to build stuff chime in.
I'm always getting asked.
benewell
Post by benewell » Thu Sep 06, 2018 12:59 pm
Thank you!
I was supposing more of an online "tech support" more than in person building :lol:
As building is more of a hobby, my limited expertise and days (weeks) of troubleshooting may not be suitable in the wild...
Sylvain
Post by Sylvain » Wed Sep 12, 2018 11:25 am
Wow!
Very nice work all arround Brian. Nice front panel too!
I hope to evolve mine into something like yours someday with the i/o matrix and igfo.
I like those small square push button switches. Might I ask you who makes those?
Sylvain
benewell
Post by benewell » Wed Sep 12, 2018 11:49 am
Thank you for the kind words Sylvain!
I used NKK's HB Series of Illuminated switches -> https://www.mouser.com/ProductDetail/nk ... cycode=USD
Brian
Sylvain
Post by Sylvain » Wed Sep 12, 2018 1:46 pm
Thanks Brian!
I was looking for something like that for another project.
Sylvain
