Trimmer in Pico, what and how to adjust
Nescafe
Post by Nescafe »
Hi,
I'm in the progress of building 2 mono pico as a selectable dual mono/stereo, there are 2 trimmer in the board, one is in RMS input and the other at symetry VCA. Could someone help me how to adjust those two trimmer and is there any notes when adjusting for dual mono and stereo mode?
Thank You.
Nescafe
Re: Trimmer in Pico, what and how to adjust
Post by Nescafe »
Hi Roger,
Thank You for the answer, I think I will get and learn rightmark analyzer first and ask You again later. And for the symetry, I should measure from pin 13 or from Pico output?
Thank You.
Nescafe
Post by Nescafe »
Hi Roger,
Thank You for the direction and explanation, I'm using Lynx Two for the soundcard.
