was HYPEX amps cheap surround system
Re: was HYPEX amps cheap surround system
Post by JR. » Fri Jan 04, 2019 11:57 am
I just placed a $20 bid on ebay for a broken A/V receiver to use as an empty chassis... Shipping cost is a few times that, but worth it rather than ugly rats nest just for the jacks....
Post by JR. » Tue Jan 08, 2019 1:29 pm
My hypex modules arrived today... they look too small and too light to be 6 channels of power amp with full power supplies.
It looks like class D is finally delivering on it's promise to be smaller, lighter, cheaper... (where were they a few decades ago?). There are probably cheaper amps out there, but it is not worth me even trying to do better than Bruno Putzey....
About one day left on my auction bid to buy a broken A/V receiver so we'll see...
Another project (maybe) coming together. 8-)
Post by mediatechnology » Tue Jan 08, 2019 3:50 pm
I have an old Denon integrated amp that I gutted the power amp boards out of.
Kept it for the switching, RCAs power supply and nice toroidal iron.
That sort of steers the project to a linear output.
You're inspiring me to revisit that old Denon.
I only need a few watts...
Good luck with your bidding.
I'm curious how the Hypex sound at low power.
Learn to code.
"Mr. Sociopath Goes to Washington" https://www.zerohedge.com/news/2019-02- ... washington
"FBI Directing CNN Camera Crew During Raid" https://www.brighteon.com/6000098956001
"Knowing Keeps Us Free" https://www.youtube.com/watch?v=5lC3mpG60sw
"Nick Sandman: The Truth in 15 minutes" https://youtu.be/lSkpPaiUF8s
Post by JR. » Tue Jan 08, 2019 5:10 pm
My camera sux at close shots but this is 4x70W of amp w/PS next to a 6" ruler.
The 2x 30W is slightly smaller but not much, just chop an inch off the left side... that is the amp part apparently.
Post by mediatechnology » Tue Jan 08, 2019 9:28 pm
You should have plenty of room in that AV receiver chassis.
Learn to code.
Post by JR. » Wed Jan 09, 2019 5:13 pm
I just ordered a couple cable sets from Hypex... anyone following me down this road, order the cables at the same time as the modules to avoid expensive shipping charges. I wasted over an hour and killed a bunch of brain cells on digikey and only sourced one 2 circuit power connector before giving up.
The auction ends tonight and last I checked mine was the only bid... If any of the electronics inside still work that is icing on the cake.
[edit- winner winner chicken dinner... won the auction. Shipping is 3x the unit cost but I can work with that... /edit]
Post by JR. » Thu Jan 17, 2019 7:16 pm
I got my basket case AV receiver, hypex modules, and wiring harness sets from hypex... running short on excuses.
The AV receiver is like 30#+ with big EI transformer, 5 1/4" fan, and big aluminum heat sink inside. I haven't been brave enough to plug it in yet, and may not yet. There is no visible rear panel fuse or circuit breaker. I see two fuses inside, both ohm out showing continuity. no easy fix there.
I am probably going to remove the amp heatsinks et all before even firing it up... There is a surprising amount of PC boards full of large scale ICs.. Ideally some of that front end still works. Since my cheap digital surround decoder kind of sux
This looks like it was serious back in the day with decent amp music power (onkyo or something like that).
