syn
That's what the top circuit does here: http://www.picocompressorforum.com/foru ... 12&start=0
"Mid" is mono is L+R. Just use the top 1240 and call the two inputs left and right.
Help with parallel & summing with THAT IC's
Re: Help with parallel & summing with THAT IC's
Hey you're welcome. Figure 10 and the post here are the same circuit. This trick can only be done with the 1240: With the 1243 or 1246 the resistors are of unequal value.
I edited your link to add the pdf session argument #page=7 so it jumps to the figure. Hope that's OK. It's a neat trick
Yeah, it is.I edited your link to add the pdf session argument #page=7 so it jumps to the figure. Hope that's OK. It's a neat trick
