Wanted to share some measurement data for the cut springs.
There are 12 springs in the MicMix MasterRoom XL-305 and my clone.
These are the target values for the spring delay timings:
Shown below are the actual measured delay and approximate length of the spring at rest.
For springs which are coupled in the middle (>18ms) there are two measurements and a total. The portion of the spring in the middle which is not coiled is not included in measurement. The coupler on these springs is randomly offset from the middle based solely on superstition. The total length of the coiled section is what matters.
T1 13.52 ms 3.54" (counted 254 turns)
T2 14.72 ms 3.86"
T3 16.16 ms 4.23"
T4 17.76 ms 4.64"
T5 19.48 ms 5.16" (2.52+2.64)
T6 21.36 ms 5.60" (2.75+2.85)
T7 23.40 ms 6.06" (2.97+3.09)
T8 25.60 ms 6.77" (3.22+3.55)
T9 28.10 ms 7.21" (3.38+3.83)
T10 30.80 ms 8.27" (4.10+4.17)
T11 33.70 ms 8.96" (4.31+4.65)
T12 37.00 ms 9.84" (4.87+4.97)
The odd numbered lines are assigned to the Left channel.
The longest line, T12, was also cut, IIRC the delay for an Accutronics" "Long" spring is 37.40 ms.
To avoid an early onset of insanity I only turn-counted the first line after measurement.
For the remaining lines I estimated the length and rough cut them a few turns long one at a time.
I then measured each line using my home-brew TDR and cut the final length using 53 µs per turn as an estimate.
I took the average of each line's final ms/inch and it averages out to 3.8 ms per inch.
254 turns is 3.54" long which works out to be 71.75 turns: The tooling is undoubtedly 72 turns per inch.
3.8 ms/72 turns is 52.78 µs per turn.
If you do this at home remember the following:
When cutting springs remember that they're stainless steel and very hard.
Wear eye protection and use the same pair of diagonal pliers that you'd use to cut guitar strings.
They will destroy good cutters.
Be very careful when forming the hook that you don't stick the sharp end of the uncut spring into your finger.
MasterRoom XL-305 Clone Sound Files: https://proaudiodesignforum.com/content ... Stereo.mp3
(Dry test tracks courtesy of THAT Corporation.)
Link to Accutronics/Accu-Bell Sound Inc. website: http://www.accutronicsreverb.com/
I think four of the 9AB3C1B could be used: https://shop.ehx.com/item/9ab3c1b/parts ... anks-long/
The only question I have is that if one buys 4 are there enough long springs...
MicMix MasterRoom Spring Reverb Project: Current vs. Voltage Drive
I initially wired the drive coils as 4Ω so I could experiment with a "simulated" current source using a large value resistor which, according to Accutronics, should be 5X the coil 1 kHz impedance. I experimented with 10-47Ω.jlm wrote: ↑Thu Dec 18, 2008 5:52 am /Hi Wayne,
I've always wondered if the current-drive, which by essence has no damping effect on the transducer might be at cause.
I think, before entertaining any other research that's the first thing I would evaluate: compare beteween current-drive and pre-emphasized voltage drive.
Though lossy it does approximate constant current well and has a huge effect on tonal balance.
Though it cuts the low end sufficiently it didn't sound as clean as unequalized "zero Ohm" voltage drive.
Like jlm years ago I'm also beginning to think damping is a factor.
Damping attenuates the undesired reflections at 2T, 4T etc. leaving only the desired odd reflections. (T, 3T, 5T etc.)
Rather than build a true current drive I decided to try equalized zero Ohm voltage drive.
I re-wired the two driver transducers in series to achieve 16Ω impedance.
I like it much better - at the moment I'm using a combination of "constant current" and "constant voltage" in the form of a single-order highpass filter with a -3dB point around 700 Hz.
Above 700 Hz it switches to constant voltage drive.
A Tilt EQ on the driver with a limited +/-range on the low end and a larger range on the top end might be useful.
MicMix MasterRoom Spring Reverb Project: Driver Equalization
I decided to try 0Ω voltage drive with the transducers wired for 16Ω.
The following are the output with pink noise driving the "chamber."
The first curve is with no high pass filter.
The transducer is inductive: Drive current falls at a 6 dB/octave rate.
The output, not coincidentally, also falls at -6dB/octave between about 100 Hz to 4 kHz.
The output response with a 680 Hz high pass filter installed:
The output response with a 1450 Hz high pass filter installed:
I went with the third flatter option which has a 6dB/octave HP slope in the driver response beginning around 1500 Hz.
This provides a constant-current-like response in the bass region and a constant voltage response above 1500 Hz.
Though I could have pushed it up a bit to to flatten response I was concerned that the bass might sound too thin.
Note the dip and peak between 6-8 kHz.
This is the direct feed-through that I talked about earlier.
In the XL-305 I used a third order LP filter to "calm down" the rising response of the true current-source output and prevent direct feed-through.
I honestly think that the voltage drive 0Ω output's damping provides a little cleaner reverb.
Coming up next: More sound files.
MicMix MasterRoom Spring Reverb Project: Sample Sound Files
100% Wet Reverb Samples
Drums: http://proaudiodesignforum.com/content/ ... s_Demo.mp3
Acoustic Guitar: http://proaudiodesignforum.com/content/ ... r_Demo.mp3
Piano/Vocal: http://proaudiodesignforum.com/content/ ... l_Demo.mp3 (originally a 128 kb/s mp3 and a little watery to begin with)
Female Vocal: http://proaudiodesignforum.com/content/ ... l_Demo.mp3
The driver needs a low pass filter to prevent the "direct" through-the-spring non-torsional HF leakage that we see in the response curves above 5 kHz that were previously-posted. You can occasionally hear it on HF transient attacks as an undelayed (sort of) "swishing" sound. Think of it as a "skin effect" of sound flowing through wire. My hunch is that at high frequencies some of the torsional rotation gets converted to longitudinal which skips over the spring turns with the spring acting as a solid rod. Since there's no useful output from the "room" above 5 kHz it makes sense to filter it in the driver.
Special thanks to The Dave Matthews Band, Eric Johnson, Billy Joel and Susanna Hoffs.
Re: MicMix MasterRoom Spring Reverb Project
Very cool to see that you're back on this project. I'm learning a lot reading these posts.
MicMix MasterRoom Spring Reverb Project: Hum-Bucking
Thank you!youthvulture wrote: ↑Tue Nov 27, 2018 7:33 pm Very cool to see that you're back on this project. I'm learning a lot reading these posts.
I'm working on a mounting method for the "sleds" and wanted to find the best hum-bucking configuration.
Not surprisingly it works better this way then the way it was previously-oriented:
MasterRoom XL-305 Clone Sleds, Pickup End.
As expected they hum-buck very well.
You can see the pickup polarity reversal in the photo above.
The drive will also be reversed to compensate and maintain absolute polarity.
With the ambient hum field on the bench the 60 Hz spur nulled about 20-30 dB.
I'll be making four L-brackets from aluminum extrusion about 3-3/4" long and use the large mounting holes to mount each sled to the bracket.
It looks like 7/8" spacing between sleds allows enough clearance.
The sections will be hard-mounted to each other with the L-brackets tying them together.
The L-brackets will be used to suspend the sled assembly, perhaps with O-rings, in a frame.
I envision the whole thing will look like a microphone shock mount.
I should add that I've been able to get a hold of the MR-II/III/IV service manual, thanks to a gracious Australian. Here it is!
- Attachments
- Mic_Mix_Master_Room.PDF
- (870.24 KiB) Downloaded 2237 times
That schematic brings back a lot of memories.
Thank you for posting it!
I think those samples sound really good, very useful.
Thanks Doug.
Today I'm making some L-brackets to hold the four sleds together.
