I did a rev 2 xls for the THAT1510 THAT1512 gain. This one opens in OpenOffice Calc and is usable in both Calc and Excel.
http://www.ka-electronics.com/THAT1510/ ... n_rev2.xls
Hi Roger,
I bought mine from the goldpoint website. They arrived this morning and feel really nice. I may have to use them on all my future projects!
My 1% resistors are here too so I can get started with the next build of these preamps tomorrow.
Cheers!
Stewart
Cheers!
Stewart
New music at xaudia.com
Hi, what a cool idea this is, I'm glad that it has a home here. It's way over my head really, but I have to say how generous it is of you to regard as "very reasonable" the questions of "why not just use a transformer" or "why not just use capacitors". It's like asking a bicyclist, "why don't you just drive?" These people just don't like fun.
Anyhow, one poster above mentions applying this topology to other preamps and I had thought along the same lines, except that how does one know if any given device would survive the trip? I see some devices have "Absolute Maximum" supply voltage given differentially (Vpos + |Vneg|) which might be taken to imply that "virtual ground" schemes are going to be okay; then for other devices each rail is specified separately -- like as in these THAT corp. parts. The 1510/1512 datasheet I have specifies +20V for Vcc and -20V for Vee. Yet it lives! I guess the only thing to do is follow Mediatechnology's lead and try my damndest to destroy something. Luckily I have too many other projects awaiting completion.
Thanks for joining us Jeffrey. I think my original reply to the transformer question at Prodigy-Pro (posed by Ted Fletcher BTW) was: "Because it's been done already." "It's been done ad nauseum." I like your answer better...It's like asking a bicyclist, "why don't you just drive?" These people just don't like fun.
The flying rails generally fake out any low voltage device by placing its local "ground," (and the rails it needs above and below ground) at some floating potential. Cable shorts at the input are a real source of interest but since the rails track the input they follow the input down to the potential of the short. Since the opposing input, not shorted, is having 48V sourced to it by a 6K81 phantom pull-up resistor and there's a fairly small termination resistor, 150R to 2K2 or so to the shorted one, the actually DC that winds up on the unshorted input is modest. There is a small amount of time for the tracking servo to follow but the TC is around 50 ms. To be really hard on the part I tried it without any protection diodes.except that how does one know if any given device would survive the trip?
Still it was quite fun trying to destroy something but the maximum current IIRC was 8 mA peak or so which is considerably smaller than the 3A spike an input cap could provide.
Well in fact, I was just teasing my brother with that very question, after he crashed his bike in a race last week, broke three ribs, a collarbone and a shoulderblade.
I guess electricity is just as subject to relativity as any other 'quantity', i.e., there's no real reason that what we think of as zero potential is more valid as a reference than any other. I don't know if that's really true, that's just how your idea makes me feel: post-Einsteinian. Do the batteries of a traveller going half the speed of light appear to have more charge from the standpoint of the stationary observer? Off topic, sorry.
I will eventually get to trying this out, I have a few 1510 sitting around. I thought it would also be neato to try at the front of the 9k or the popular Green pre circuits. I know you're helping develop applications for THAT so I hope this suggestion is not in bad taste.
Go for it. I think they'll hardly notice their rails being moved about.I thought it would also be neato to try at the front of the 9k or the popular Green pre circuits.
Great minds think alike Have a bunch of Russian-made thumbwheels here, they're cheap on eBay,Wayne wrote:It hit me. Why not consider the ancient thumbwheel switch as a means of precisely setting mic preamp gain? These have gold plated contacts and have lasted 30 years in my Mom's kitchen timer. In the studio one could know exactly what gain, to the dB, was being used. Great for repeatability and pencil-based "total recall." Didn't the Sphere or Quad Eight do this on the EQ with lever switches? Since our preamp doesn't have up to 99 dB gain we might want to black out those positions above "6" on the first digit.
am already using them for a 6-decade resistor-bank and will be using the rest for exactly this application: repeatable mic-gain setting.
But forget about all that repeatability, I just dig the retro-look
Regards,
Peter
Peter! Thanks for joining us.
Yes a very retro look those thumbwheels...
I think we discussed this once before.. A two gang switch for 10s and 1s could give more than enough range, putting the 1s on a second gain stage would simplify managing gain interactions. I think I've seen thumb wheel switches with stops in them which could be nice as we don't need 100dB of gain.
I prefer real resistors to pots and in a few semi-custom pre's i found a 12 (13?) position rotary switch quite nice.
An old friend used some of those thumbwheel switches in a custom console for mute-solo groups (a one off design he found very useful for mixing reggae.) Being able to mute and/or solo groups was a little poor man's automation.
I don't think the thumbwheels I have can be made to stop at a certain setting, so I'll be shorting the higher
10-positions to keep the same gain as the highest meaningful setting.
Bye,
Peter
Bye,
Peter
