MEP-250 Bridged-T equalizer
Re: MEP-250 Bridged-T equalizer
Post by billshurv » Mon Mar 25, 2019 7:33 pm
Suddenly I remember why I am using a PC for parametric duties. I'd never find time to build that.
Post by Gold » Tue Mar 26, 2019 2:02 pm
It took about 100 hours to build. The second unit I expect to come in at half that or less. These EQ’s are for a console that will be used daily to generate billing. I certainly wouldn’t do it just for fun. These cost a fortune to build. The second one is well in its way.
Post by Gold » Wed Apr 03, 2019 11:17 am
Some notes on a real Sontec. They use polystyrene caps for the smaller value in the tuning circuit. I guessed right on that. This one used Evox (Kemet) polypropylene film caps for the larger value. This one had a noise floor of -82dBu unweighted. The one I built has a noise floor of -86dBu.
The one I built doesn’t sound exactly the same but it’s in the same ball park. Mine is a two opamp 250 style. This Sontec is a 4xx and is a three opamp version. On the three opamp version sum and output use separate opamps.
Bill Wilson
Post by Bill Wilson » Tue Dec 10, 2019 6:12 pm
In the Sontec circuit C25's value is 33mfd, 6vdc. The values for all 5 filter frequencies are listed ln the lower right hand corner of the schematic.
Post by Gold » Wed Dec 11, 2019 2:17 pm
The ones I built aren't an exact clone of a 250 or 430. The tuning capacitors aren't the values listed in the 250 schematic. It's kind of a mashup of the 250 and the GML 8200. The 430 uses three op amps in the summing section. One for Input, one for Output and one for summing.
