T Attenuator Termination Kluge
Re: T Attenuator Termination Kluge
Post by mediatechnology » Mon Oct 07, 2019 3:23 pm
-56 dB at cutoff seems high to me.
"Secret Court Issuing Website "Takedown" Orders in America, Targeting "Vaccine Truth" Sites" https://www.naturalnews.com/2020-01-23- ... downs.html
Post by Gold » Mon Oct 07, 2019 3:33 pm
You would expect more attenuation at the fully CCW position right?
Radardoug
Post by Radardoug » Mon Oct 07, 2019 3:46 pm
It could be your board, and the fact you are going balanced to unbalanced and back. But I would have thought the last position of the attenuator would be an off position, with very high attenuation.
Post by Gold » Mon Oct 07, 2019 3:58 pm
I figured it out. The 10K TKD didn't like the 5K termination resistor for the T attenuators. When I bypassed the termination resistor I got over 80dB cutoff. I'll have to think about the wiring now. If I put the TKD before the 5K Bridged T switches they will still see a 5K load, so that probably won't work. I guess I could terminate the 5K Bridged T at the attenuator. Feed the TKD pot after the termination and use a higher value termination resistor on the PCB's.
Post by Gold » Wed Oct 09, 2019 12:03 pm
It turns out it had nothing to do with the termination resistor. There were a few things that needed sorting out. The major thing was a different grounding scheme. Now I get cutoff better than the Portable One can measure.
I had to put the TKD pots before the Bridged T attenuators. The 12Ω-14Ω series resistance was enough to throw the gain steps off by too much. Now with the pot before the attenuators I'm getting gain steps that are within a few hundredths of a dB accurate. Channel matching when using the pot looks like it's within about 0.2dB over the whole throw.
Radardoug
Post by Radardoug » Wed Oct 09, 2019 3:04 pm
If at first you dont succeed, keep at it! Well done!
Post by Gold » Wed Oct 09, 2019 8:20 pm
Thanks. I’m happy with it. Crosstalk -90dBu at 20K. The input is AC coupled. After that everything is DC coupled. Now I have to put the new pot in the other Output Amp.
Post by emrr » Thu Oct 10, 2019 6:37 am
Good news. T attenuators get screwy so easily if the surroundings are funky. I have measured so many odd things.
Post by Gold » Thu Oct 10, 2019 11:53 am
I'm seeing something I don't understand. When feeding a 1K 0dBu tone in, with 11db of gain (zero attenuation with the attenuators) and the fader fully CCW I get a kill below the measurement range of the Portable One. With the fader still all the way down I get a kill of -86dBu with the attenuators at -3dB (8dB of gain). When the attenuators are at 0dB on the dial (-11db gain) I get a kill of -79dBu. It stays at that value for the rest of the switch positions. I get more kill with 11dB gain than I do with -11dB. -79dBu isn't a deal killer but if I can improve it I'd like to.
Post by Gold » Fri Oct 11, 2019 1:54 pm
I spent some time trying to improve this. I noticed there was 20KΩ to ground at the Unbalanced Output feeding the Fader-Attenuator. I sub'ed in a couple of values and saw a pattern. Then I put a rheostat in place of the resistor and adjusted for the deepest cut. Curiously the value was 2k5Ω. Half the termination resistance. Then I tried changing the 5KΩ termination resistor to 2k5Ω. Bingo. I have a 6dB improvement now with a cut of -85dBu at the "0" position (11dB of attenuation). Close enough for government work.
