Loftech TS-1 Schematics
Re: Loftech TS-1 Schematics
Post by JR. » Sun Nov 26, 2017 11:50 am
I found a nice back lit LCD display with 16, 1/2" high characters... not cheap (>$20) but with 16 characters I can display decibel level and frequency at same time.
There are cheaper displays but with much smaller characters. The only cheap/large character LCD was 4 digit clock display....
Post by JR. » Sun Nov 26, 2017 2:52 pm
This is fun thinking about this....
I could use a 16B DSPic that has 2x16b DAC built in, but only 12 bit A/D built in... Or in the $3-$4 range I can get a 24b stereo in/stereo out codec... that I can hang on a cheaper micro...
Probably use a DPOT to pad scale the input range down to the 3V codec.
Now that is probably more bits and I/O than I need, but why scrimp?
I need to soak this in beer tonight. 8-)
Post by mediatechnology » Sun Nov 26, 2017 5:06 pm
After soaking it in beer you might want to start a thread in the Design area of the forum. I'm liking this.
Other than the analog front end for the measurement A/D and the balanced output there doesn't seem like much additional outboard circuitry would be required.
Rather than a DPOT you might consider a resistive pad since the DPOTs THD would limit you if you ever wanted to use the same engine to perform THD measurement. You would want a low distortion coarse output pad too wouldn't you?
Post by JR. » Mon Nov 27, 2017 11:27 am
Wayne can you split this topic and move this veer to another forum?
Moderators should have that capability.
If not I will start another.
Post by mediatechnology » Mon Nov 27, 2017 12:00 pm
I will move that. Not something I do often so I have to remember.
What shall we call it?
Post by JR. » Mon Nov 27, 2017 12:09 pm
TS-too.... TS-1 revisit
Post by mediatechnology » Mon Nov 27, 2017 12:13 pm
