Single Stage Gives Logarithmic Gain Steps, EDN March 3, 1994
Post by mediatechnology » Mon Oct 12, 2015 5:02 pm
"Single Stage Gives Logarithmic Gain Steps," Allen Windhorn, EDN, March 3, 1994
This circuit uses positive feedback to modify a linear taper pot to provide logarithmic gain control.
It's similar to the circuit trick Douglas Self used in the Soundcraft panpot.
"Single Stage Gives Logarithmic Gain Steps," Allen WIndhorn, EDN, March 3, 1994.
https://proaudiodesignforum.com/images/ ... 3_1994.pdf
SOCIAL MEDIA PLATFORMS should advance FREEDOM OF SPEECH. Yet too many Americans have seen their accounts suspended, banned, or fraudulently reported for unclear “violations” of user policies. No matter your views, if you suspect political bias caused such an action to be taken against you, share your story with President Trump.
White House Tech Censorship Reporting Link: https://whitehouse.typeform.com/to/Jti9QH
BANNED VIDEO - UK Police Escort A Muslim Mob To ATTACK Tommy Robinson:https://www.newswars.com/censored-video ... n-england/
Re: Single Stage Gives Logarithmic Gain Steps, EDN March 3,
Post by JR. » Mon Oct 12, 2015 9:18 pm
Actually it is the gain relationship for most decent mic preamps made the last few decades.
Just imagine two op amps with the linear gain pot between the two - inputs... presto log gain function.
Ideally you want a nonlinear pot (slower at the low R end) because the log/exponential gain increase is too fast at the end hop off.
Post by mediatechnology » Tue Oct 13, 2015 5:54 am
It looks like half an instrumentation amp at first glance.
But the pot is between the "+" inputs controlling the positive feedback not the negative feedback we are used to seeing.
Post by JR. » Tue Oct 13, 2015 8:58 am
My bad... I was a little too fast on the trigger...
Post by mediatechnology » Tue Oct 13, 2015 9:17 am
I "double-taked" that one a couple of times too...
Sort of like when you see an op amp cascaded to an inverting buffer and overall NFB feedback taken into non-inverting input.
The first time you look at it you go "wait a minute. Was that drawn right?"
I need to find Self's Soundcraft pan pot with both positive and negative feedback.
So the question is, can a dual section pot varying two shunts be used in an instrumentation amp having both positive and negative feedback to obtain linear (or at least more linear) gain control vs. rotation?
The time is 09:16 on October 13, 2015. :idea:
Turns out you can enter a "Citation of prior art and written statements" into a patent file.
Cheaper than a re-examination....
Post by JR. » Tue Oct 13, 2015 10:28 am
mediatechnology wrote: The time is 09:16 on October 13, 2015. :idea:
I am confused again....
I did some research into trying to squash a dubious patent and you need to be careful if/when you trigger re-examination since a weak contest will just make the bad patent stronger.... Adding prior art to a file does not automatically spank it. In fact my understanding of the law is that the inventor is supposed to advise the PTO if (s)he even learns of prior art... I have sent prior art to inventors before...tends to shut them up.
Post by Gold » Tue Oct 13, 2015 12:16 pm
I think this would be useful as an input to an O'scope used in XY as an audio monitor. It could maintain a constant display size regardless of input level. NTP did that with the little XY display meter they had in a Danner cassette format.
I have the documentation for that somewhere. I'll try to dig it out and post the discrete version log amp they made.
Post by mediatechnology » Tue Oct 13, 2015 1:21 pm
Great idea Paul.
That would be useful. I'm always using the 'scope in X-Y and am constantly reaching to change two input attenuators.
Re: Single Stage Gives Logarithmic Gain Steps, EDN March 3, 1994
Post by mediatechnology » Thu Nov 15, 2018 12:45 pm
Soundcraft active panpot using positive feedback.
