NE5532 NE5534 THD
Re: NE5532 NE5534 THD
Don't diss cascodes... inside ICs you can support all kinds of complexity with little cost impact.
I recall having to arm wrestle Jack Sondermeyer (father of the CS800) to add an op amp front end to his baby. I wanted a balanced input and he was concerned about degrading the 100 dB+ dynamic range. He disappeared into his lab, and after measuring the noise floor of a decent balanced input he stopped arguing. (CS800S was first model with balanced input, you're welcome everybody 8-) ).
+1.
It's all about die area. Capacitors and precision (trimmed) resistors are the real estate hogs.
Transistor area is cheap.
Post by ricardo »
JR. wrote:Don't diss cascodes... inside ICs you can support all kinds of complexity with little cost impact.
I don't. I use them when I need them.
But for a simple Power Amp (single device VAS, EF2 Outputs), their advantage is too slight to be seen if you are doing everything else right (eg NPN i/ps). I'd cascode the i/p LTP if I'm chasing 1ppm THD20k and was getting 2ppm without (a sorta 'real' example). But 'simple' isn't quite in that league.
Don't forget I'm the guy who agonises over adding 2 resistors :o
JR. wrote:(CS800S was first model with balanced input, you're welcome everybody 8-) ).
Thanks JR!
