dBx 3BX Three Band Dynamic Range Expander
Schematics for the dBx 3BX dynamic range expander. One of the first applications I saw using the non-linear capacitor.
dBx 3BX Schematic
Large format: https://www.proaudiodesignforum.com/Images/jpg/3BX.JPG (4.4 MB)
When I had a 3BX I had thought about modifying it to be a feed-forward three band compressor. Check out the derived filters and FET switching inside the OA feedback loops as well.
Wayne
EDIT: 1979 patent for 3Bx showing the non-linear capacitor: https://proaudiodesignforum.com/images/ ... 177356.pdf
Re: dBx 3BX Three Band Dynamic Range Expander
That looks a little bit crazy. Probably just that they put it all in one drawing! What era is this device?
There is a second page I need to post with PSU and metering I had forgotten about.
It was early 1970's era.
Interesting the ancients are stealing our ideas again...
Those active cap multipliers with diode clamps to make it fast for large changes and slow for small changes is very similar to a circuit I did in the '80s for a NR... While I added a few other tricks too, it was the same general concept.
JR. wrote:Those active cap multipliers with diode clamps to make it fast for large changes and slow for small changes is very similar to a circuit I did in the '80s for a NR... While I added a few other tricks too, it was the same general concept.
Still found as the NLC in the Pico and THAT DN-114: http://www.thatcorp.com/datashts/dn114.pdf
Was yours in the NE570 compander we posted here?
JR. wrote:Interesting the ancients are stealing our ideas again...
On that note I'm tempted to start a thread on the "superbal" cirrca 1982.
viewtopic.php?f=6&t=252
here it is, a NE572 based tape NR
I did a bunch more than just the dual time constant C... I give a full description at the above link.
enjoy,
That's the one I remember. Very clever.
Non Linear Capacitor in 1979 Patent 4177356
1979 patent for 3Bx showing the non-linear capacitor: http://www.waynekirkwood.com/images/pdf ... 177356.pdf
ricardo
Post by ricardo »
JR. wrote:viewtopic.php?f=6&t=252
I grovel at your feet in awe, Oh Guru JR :o
