DIY 3rd hand soldering tools
Nescafe
Post by Nescafe »
Happy Easter everyone :-D
http://www.instructables.com/id/Third-H ... r-electro/
I just place an order for the hose :-D
Re: DIY 3rd hand soldering tools
Here is an old DIY helper I made... I soldered it to a battery clip so that would be heavy enough to keep it steady.
We need low performance helper robots for all those jobs that don't require skill just another set of hands.
I have that same Keystone 9V clip...
I like the "robot arms" made from coolant hose that nescafe linked to.
I might actually order some as well.
When I worked at SSL I got to see a lot of people's shops and the primitive clip-lead thingys were very common.
About as popular were drilled wood blocks to accept XLRs, TRS and RCA plugs.
I never liked using the blocks since most were oriented vertically and I prefer to solder connectors horizontally.
I really don't miss the days of terminating cables and wiring DB-25s.
I've just always used a small Panavise or General Tools vise for connector soldering and have a PC-board soldering vise.
If I didn't have a printed circuit board vise I'd have to have the clip leads.
I can see the "robot arms" with being very useful for that - probably better than the PCB vise.
Nescafe
Post by Nescafe »
The battery base is a good idea, I think that will be heavy enough for base job. I really want some Panavise Jr, but hard to get here in my country, so DIY tools like that is really help. What I use now is widely available third hand that is very frustating to use :(
