This is me! [new member introduction] warning! loong post
Re: This is me! [new member introduction] warning! loong post
I think these were made around 1971-1972. I noticed that the lip behind the bezel was made by cutting away material over the full length of the inside. For the basic "tube" there are only 4 joints at each corner. Walnut must have been really cheap then since a lot was cut away. A saw cut on each side served as a circuit board guide for the clock board.
My brother isn't alive to ask but I think my Dad may have made the prototype. I think I remember the cases costing around $6-7. What a bargain even then.
- Foona
WOW!!!
I have completely fallen in love with the design! They look really solid and sturdy
unlike everything else that exist on the market nowadays. Real piece of craftmanship!
Lovely, just lovely!!
...are there still some assebled clocks around?....might want to purchase one.
I wished there were more clocks.
These used a very early AMI clock chip that was probably one of the first on the market. It had LCD drive capability but the display was 7 segment incandescent. There was a company at the time that made incandescent 7 segment displays in DIP packages so the clock used a bunch of NPN transistors to buffer the PMOS IC outputs.
NIXIE tube clocks are hot right now. I built one of those using RTL logic back when I was 12.
- Foona
aaaaw, I am so envious!!!! I really want one.
You just gave me an idea of what to build after the PICO is done.
Nice work.. you've been busy..
- Foona
Sadly all the CD's have been sold out.
BUT, I will be making more within 2 months,
and i'll make shure you get a copy. Promise!
